dlogvine
Master Chief Petty Officer
- May 4, 2015
- 839
I'm replacing a Volvo penta 4.3 v6 original engine with Mercruiser 4.3. The outdrive and gimbal housing is replaced with the alpha one gen 2 version. I had to drill 2 holes in a transom to fit the alpha 1 gen 2 gimbal housing and decided to replace the rubber gasket/seal in the gimbal. The new one is slipping from the grove. Should I glue it down? And if yes what kind of glue should I use? I can use some waterproof sealant adhesive or should I go for something stronger like bellows adhesive? Thx.
