dlogvine
Master Chief Petty Officer
- May 4, 2015
- 839
I bought a hull of a 2004 Larson 180 sei. It had originally a 4.3 Volvo penta engine, but I'm putting in a 4.3 mercruiser. There is still original wire harness from the dash to the engine, and it has an original shifter. I have a couple questions,
1. Do the mount holes for Volvo penta engine match the mercruiser mounting holes.
2. Can I use the Volvo penta wire harness for mercruiser engine as long as I change the main connector to hook it up to the mercruiser engine harness. Do the wires have the same color matching as mercruisers?
3. Can I use the Volvo penta shifter, or should I change it also with the one made for mercruiser? If I can use it what changes should I do for the wiring?
4. And the last one is more of a decorative question, Alpha one gen 2 has speedometer pilot inside an outdrive, while on this boat it is external. Should I leave it as is or remove the external pilot, while plugging the hose to the outdrive?
thank you.
thank you.
