DJ_Allatoona
- Feb 24, 2008
- 187
I just bought a used motor. Mercury 75hp made in 1986. Dude says it was sitting on a junk boat in his neighbor's backyard for at least 5 years that he knows of, likely many more. When I picked it up, we did a compression test, 130-ish on every cylinder and the starter seems capable. It turned over nicely using a jumper on a battery. Good spark on all wires via a tester. Carbs look good & clean to the eye. It was not connected to a remote or hose, and the gearcase is shot so we didn't try to start it. We did shoot oil into the plug holes before the compression test.
I don't know the condition of the fuel pump or the guts of the carburetors.
I still have to do the T/T wiring and un-seize a very stuck steering cable that was cut off on the starboard side. But I'm close to turning the key for the first time.
This is new for me. What should I do besides use a fresh battery and good fresh fuel? I never had to use starting spray on any motor before. Should I get a can beforehand just in case?
What are the odds it just starts up and purrs like a kitten? I'm very eager to do it, but it's still a few days away.
