This thread is a continuation of my previous thread where I had the oil analyzed and it had antifreeze and high metal levels in the oil.
I want to have a boat I can depend on next season so I think the best course of action for me is to either purchase a new GM long block or have one built with better parts provided the cost is somewhere in the ballpark. As Scott D has mentioned in my previous thread a new 377 LB can be purchased for around $4200.
I found a good shop that has all the best equipment and builds a lot of race engines and will do the job. He said he will put a manifold with carburetor on it and run it on the engine dyno before it leaves the shop. I got all the casting numbers so all we need to do is sit down and go over the list of parts to put in the engine.
When I pull the bad engine in the spring, I plan to use that as a core, should I need to rebuild the other motor.
What I have: Block Casting 10239906. 350 CI Vortec truck Gen 1 crate motor with stroker crank making it 377 CI
Head Casting 10239906
Both have Made in Mexico on the casting if that matters.
My goal: I'm not looking to build a high HP engine. It has to run with the other engine which is 320HP. I wouldn't mind a small bump in power but I don't want to add expense needlessly. Also the shafts are only 1 1/4" stainless steel and it's a fairly heavy boat, so I don't know much they can handle.
Recommendations for the LB build ?: The shop owner said he has seasoned blocks and better GM heads that will bolt right on for a good price.
I have read that the Scat crank kit is reasonably priced and probably good enough for what I need Is that the best option for my case?
Also what cam and piston choices would be suitable for this build?
Any other upgrades I should consider? Oil pump etc.
I will also need enough parts for him to run the engine on the dyno, so I wlll need an oil pan, harmonic balancer marine water pump. Some other parts that are needed like the distributor I can pull from the old engine. Is the Mercruiser oil pan a cast pan I see it is about $600. Also is the harmonic balancer the same as stock GM truck engine?
That's it for now. I'm sure I will have many more questions.
