This question may have been asked already, apologize if so. I have a 1985 mercury 60hp outboard on a 17ft Monark bass boat that I recently restored. In the process of making a shake down run I discovered that the fuel system had issues, and the fuel pump was failing. After rebuilding the pump and replacing the entire fuel system from the carbs to the tank, the engine ran great for a bit, so I loaded it up and was about to put it on the trailer when I heard a fairly loud ping in the powerhead, and it began to rattle. Having a good idea of what had happened I immediately shut the engine down and brought it home. I pulled the plugs and used a bore scope to have a look. As expected the top cylinder appeared to have run lean (I suspect from being run with the failed fuel pump). The damage to the piston was obvious. So I proceeded with a teardown of the powerhead to determine whether the cylinder walls were salvageable. Unbelievably there isn't a single mark on the cylinder walls and the crosshatch is still fully visible in all 3 cylinders. The top piston is obviously wiped out, but the other two are still in decent shape. My question is whether I should replace all 3 pistons at additional cost or reuse the 2 lower pistons and replace the top? Thoughts, concerns...
