andrewterri
- Jun 25, 2014
- 437
If you still have trouble finding the sensor page let me know. I can go connect to my boat and get step by step directions for you.
After a while we put a new head, new gaskets and assembled the engine. However the engine did not start, the starter works great. We checked everything and there is no power in the engine electronic circuit, but some dash instruments work(oil pressure, trim , fuel , temperature and voltage), the buser works but the obd lamp not.
I can help you a little with the vesselview. You can not clear the code from the engine. There is a clear code for the app only. You can clear them from the app than see if they come back which it sounds like it will with what you have going on. If we have the same version the vessel view does have oil pressure and water pressure readings but they are kind of hard to get to.
Once the boat is connected tap on the rpm reading and this will take you to the gauge pages where you can select 4 different pages made up of all sensor readings your engine has, even some you do not. For example, mine shows incoming seawater temp, I do not have that sensor so it just shows 32.
You have to turn the key on to where the vessel view turns on to connect and get to what I was telling you about. If you are not connected to your engine than the pages will not show up.
I don't think those faults are true faults for your motor. There is a concern for the misfire, but if its running good, go boating
Timing is set this way only, its not done with a timing light
