well i have returned to the boat to try and find out why it tried to sink on me.
twin 7.4l mercruiser bravo II outdrives.
last april the port engine/outdrive developed a major leak that eventually forced me to truck my 35ft thundercraft to the storage yard.
viewed from the inside between the two engines, in the end i could see a curtain of water sliding down the inside face of the transom under the motor.
long story short, plugged the exhaust bellows, put it in the water. still leaking. mechanic knew of two ports on the bottom of the outside transom plate of the outdrive. they are about an inch and 3/8ths in diameter, one on either side of the bottom. plugged these, back in the water no leak.
what i need to know is where or what do these ports go to. outdrive is off, exhaust bellows is removed. engine still in place with little room to see anything. cannot see where the two ports would enter the wye tube and be related to exhaust ducting.
original theory was that the top of the wye tube was corroded through from a leak but now not so sure.
any help?
thanks
stephen
any help?
thanks
stephen
