I do most of my own repairs but when it comes to outdrive seals, I have a pretty good mechanic and I have him take care of that. He's doing my upper seals right now.
I have built up an air pressure tester where I use a bike pump to do the air pressure test. I found the idea right here on iboats! So, the tool and procedure from iboats is what I use ... drain the lube, remove the drive (it's an alpha 1 gen 2), air it up with the bike pump to 10 lbs and make sure it holds the air.
So -- my mechanic (who I believe is a pretty damn good greasy wrench mechanic) has a different way of doing it. He says to load lube into the outdrive and then air pressure test it. Seems to me, if we find a leak at that point, you have to drain the lube and you've got a big mess to deal with before you can get back into the drive.
Now, there is no way to convince this guy to do it 'the iboats way' instead of the way he has been doing it for decades. And most importantly, I don't want to insult him or **** him off. A good mechanic is hard to find in the desert of Arizona!
Is there any simple explanation or reasoning that might help me out here?
