I removed my engine and transom assembly (2009 350 MAG SeaCore - 900 hours) to do a list of maintenance items e.g. leaky oil pan, gimbal bearing, coupler, bravoitis and the infamous leaking steering pin seal (stainless steering pin) etc. When I tore down the transom assembly, I found that there was quite a bit of corrosion around the steering pin seal and the lower bushing, to the point that a new seal will not stay in place. Also, about a third of the material around the bushing is corroded away. The gimbal housing is junk the way it is but given that a new housing is around $2000 and a transom assembly is nearly $3000, I was wondering if anyone knows of a machine shop that would do this kind of work - specifically welding/remachining on saltwater components. I know it's a longshot but the rest of the outdrive is in near perfect condition with no corrosion anywhere else.
