 To play with prop pitches professionaly need to install an induction tach go for a wot run solo boating on flat calm water cond and report the achieved max wot revs. Compare to the factory min*max wot rpm range to check if the motor is running around the lugging rpm side which is bad. A less pitch number will bump the wot rpm higher along bettering the top end speed. What's the current prop number stamped on the body or blade ?
Happy Boating
right now it has the factory (i think its factory) 8x7p
To play with prop pitches professionaly need to install an induction tach go for a wot run solo boating on flat calm water cond and report the achieved max wot revs. Compare to the factory min-max wot rpm range to check if the motor is revving around the lugging rpm side which is bad. A less pitch number will bump the wot rpm higher along bettering the top end speed. What's the current prop number stamped on the body or blade ?
Happy Boating
Must be 100% sure on what you have and go from there maximizing a less prop pitch. Without a tach will be a wild guessing determining at which wot rpm the motor is reving at at full throttle powering the new boat.
Happy Boating
You are talking about the tachometer where you wrap the wire around the spark plug?
So that's a non through hub prop, right ? If motor runs as a champ at all throttle setttings, only needs a prop maximization. But if isn't known at which max wot rpm the motor is revving up how can you determine how much less prop pitch the motor needs to improve its water performance powering the latter boat.
Have discovered that same motor powering 2 different type of boats will not work same, boat lenght, hull shape, drag coefficient, trim, motor height and deck weight distribution accounts exponentially for that to happen.
With respect to the current prop, if newer less pitch props are non available, send that prop to a prop shop, have it repainted along a nice 2 less pitch rework from current factory delivered prop pitch..
Happy Boating
That motor needs to rev at wot inside its wot rpm range factory stated which you can't possibly tell by simple ear tach no matter if having a musician ear. Ideal would be to rev around its max wot rpm range. I've done dozens of prop maximizations on different boat types with spot on results. I'm called locally the wizard of prop maximization for under powered motors, but if you want to keep boating that way it's entirely up to you. You will never know what you are missing by not going straight for a prop maximization.
Won't break any world record with said motor, but will push/plane that combo better than with current factory delivered prop and that was what you were looking for on your post.
Happy Boating
Okay I’ll go buy a tach and when it’s warm enough I’ll see what it says
