1stmatekate
- Jan 14, 2012
- 5
Hello all, I have a 1977 16 ft Starcraft Super Sport which I've owned for 8 years. The previous owner had hit a submerged stone wall at speed and damaged the bow just below waterline, he had repaired the damage with a marine based bonding agent and all was well until last summer when it started to weep from the inside causing blisters and a whitish discoloration when it drips on the trailer. I removed most of the repair on the outer hull last fall and will open up the flooring in the bow this spring. My question is what do I use to repair the damage after it is all cleaned out? The marine bonding agent worked well enough but snooping around the internet I saw several versions of aluminum brazing rods advertised. Any suggestions would be appreciated.
