No he hasn't, he was just quoting from what he found.
if the recirc valves were clogged, they would't draw fuel from behind the carbs as the vacuum wouldn't reach the intended "sump"
If they were stuck open "maybe" it would do something negative. since on each vacuum (up) stroke it would suck from the sump, but on positive (down) stroke it would push that fuel back to the sump.
see my thread
https://forums.iboats.com/forum/engi...de-225-hp-1986
It was my understanding, maybe racerone can confirm, that the recirc valves was introduced to help burn some of that puddled fuel and help the motor re-start after it has been running for a bit, then **** down for a bit.
this statement I don't agree with
"The recirc valves remove fuel puddled in the intake on that engine, if they are clogged, the engine will die when you throttle up, it pulls all the puddled fuel into the cylinders and drowns out the spark so to speak."
