Ok, FR I do honestly appreciate the help. The wiring diagram was very helpful. Hopefully this is my last question. And it may be stupid. So I followed 12v to from the battery to the starter, then from there to terminal block. As I’m following my wires to my ignition I have 12 v before my plug going towards key, I got 12v after plug. But don’t have 12v on red wire at my key. Could not having 12v there be causing my issues?
If the engine is cranking, you have 12v at the key. The starting system and the ignition system only ever come together at the negative post of the battery. Deal with them as 2 completely separate systems.
The power pack is powered by the stator (a simple coil of wire) under the flywheel (which has magnets on it). It only gets power once the flywheel is spinning (at a minimum of 300rpm). Any coil of wire that is being 'cut' by a magnetic field will generate a current. That charges up the power pack (or at least a capacitor inside the pack). Also under the flywheel is a 'trigger', that pulses the power pack to fire one coil or the other (using the same principles of magnetic fields and coils of wire). There is NOTHING in the ignition system that is connected to the battery in any way. Although not in any way recommended, but you could remove the battery completely, and using a pull cord, start the engine and it would run perfectly without a battery.
It's highly unlikely that reversing the battery damaged the power pack, as that 'kill' wire has over 300v on it when the engine is running (ask any marine mechanic how they know that.
) Reversing the battery and putting 12v on the kill wire will do NOTHING to the pack.
The only thing you will have killed is the rectifier, and that's already been dealt with by the suggestion of a simple bridge rectifier from Tandy. The rectifier in the engine would have originally been rated at about 6 amps, this one is 35 amps. The only thing that will kill that is corrosion (and reversing the battery again. Buy 2)...
What are you touching on the power pack that is giving you a spark? (When the engine isn't running, every wire on the pack should be dead)
Chris.......
