Took boat out this morning with pressure gauge and meter attached. After about 5 minutes voltage dropped to 0. I connected a second ground wire to the pump , still no voltage. Jump power from another source and boat tan fin back to dock. Took the plugs out of the ECU and examined them, they look fine, took relay off and switched it dith another one. Still no voltage to pump. Tried turn batteries off and back on still no voltage. Hopefully now i can locate problem since its not coming back on.
