Can someone tell me what this is for ?
Elias799
Hello I'm doing a Bellow and a gimbal job on my Alpha One Mercruiser Gen 2
I was wondering if anyone can tell me what this gasket is for
Grub54891
That would go in the u-joint bellows. Before installing the drive, it seals against the drive cone to keep water out of the bellows and boat. Have you pulled the drive? It will be there unless someone didn't put it in. If not you may have some very rusty parts in there.
Elias799
I have pulled it off already and have replaced all the bellows. But i did not really notice where that gasket came from
So just to confirm
U jount bellow- bellow retainer ring then this gasket and finally i can install the drive unit ?
achris
More fish than mountain goat
It MUST be glued into place... It goes into the bell housing and stops up against the stainless steel bellows lock ring.
Chris.......
Elias799
How do you guys hammer in the bellow retaining ring ? I destroyed one already šŸ˜”
Bt Doctur
You dont, you get a can of "power tune" from a merc dealer , spray the bellow and ring and just push it into place this is assuming to installed the bellow correctly over the ridge
AShipShow
Yep, practically goes in by hand with powertune.
