Hi all. I am new to this forum. I’ve been looking around a bit and found some items I can rule out as being the issue but have yet to find the solution. I have power at the gauges, 12v at the igntion switch in run. When turned to try and crank it drops to 5.6 volts at ignition. Also, only 5.6 at the positive terminal on the coil in run position. The choke resistance wire (from coil to choke) gets hot. New batteries, ignition coil and slave solenoid. It will crank when I jump from the battery to the slave solenoid. I tried bypassing the neutral safety switch but no dice. The hot choke wire is a “newer” discovery and has me thinking there must be a short somewhere but I’m not much with electrical so I thought I would ask here first. Any help is appreciated. Thanks
Edit: I put on another slave solenoid with no positive results. I tried jumping the new slave solenoid directly from the battery and it cranked for half a second but then nothing. Did I fry the new solenoid? What the heck is going on??
