- Jul 23, 2011
- 51,365
its a simple motor with a simple points ignition. with the understanding of mechanical things, it should be easy to figure out.
I did say that and have determined that it must be something electrical. Here is where it gets really weird. Per suggestion from this forum, I pulled the drive today. To my surprise, the engine cranked with the plugs in. I had to use both (all) batteries as it did not crank with just the one. I am 99% sure that the new cranking battery I bought is bad. I put the drive back on and strangely enough, it cranked with ease. I hooked up water and tried to get her to fire. After about 10 seconds of cranking and basically “running” via the starter, I stopped turning the key to give the starter a break. After a minute or so I tried to fire it again and no crank no nothing. I wiggled and jiggled wires and even cursed a bit. She cranked, or not, and tried to fire several times, sporadically, with no rhyme or reason over the next half hour. I have zero idea what is going on. It is possible that I could go out right now and she would crank, maybe fire, or do nothing at all. I’m at a loss. Any ideas are very welcome. ThanksDidn't the OP say that it cranked when a battery was connected to the slave, or did I misunderstand? If that's the case, why is everyone concerned about a mechanical issue rather than straight electrical?
You have a bad connection somewhere. And that could also mean the connection, on the negative side. Check all your negative cables, and the 'connection' between the starter and the engine block!
Chris.......
by clean, you used 320 grit or a wire brush on the end of a drill, right. the connections need to be shiny, then after you bolt them firmly, you need to seal them with electrical varnish
if the battery cables are stiff or have green fuzz coming out near the terminals, replace the cables.
as soon as I release the key from the “fire” position,
Ayuh,...... That's the "Start" position of the key switch,.....
Check the key switch with a test light,.....
You need power out the ignition post to the purple wire, with the key in the "On" position,......
If you have power there, check the tiny (+) terminal on the coil, with the key "On",.....
No power at the + side of the coil but the wire going to the choke from the positive side of the coil was smoking and super hot.
That's Impossible,....... reread what you wrote,....
Post a picture of your set up. It doesn't sound right. The purple wire from the ignition should be 12 volts with the ignition on. The resistance wire should also be purple, and supplies eight or nine volts or so to the coil with the key in the on position. That's what keeps your engine running. Check the resistance of your gray wire to see if someone replaced the purple with just a regular non resistance wire. The resistance wire gets pretty hot, but definitely shouldn't smoke. The only gray wire at the coil should be from the tach, to the negative terminal. The purple and yellow wire to the coil is from the slave solenoid, and supplies with full 12 volts while you're cranking the engine only. If the resistance wire isn't supplying voltage to the coil, then the engine will attempt to fire and then die as soon as the key moved back to the on position.
Ok, that looks correct. Yeah, that gray wire probably started its life purple. You should have a full 12v at the choke with the ignition on, and it should be slightly less than that at the coil (+) with the ignition on. So you have at least one problem there. Guessing that you're getting 12v to the coil when cranking (from the slave solenoid), but not enough from the ignition wire (choke) to keep it running. For diagnostics, might want to run a known good 12v to the choke and see what happens. You'll have to chase down where you're losing voltage starting from wiring harness-->ignition-->back to the choke after that if it works.
EDIT: What is the voltage at the (+) terminal of the coil in the run position?
