Trevthefox
- Sep 25, 2018
- 101
Hello again,
I have a wiring question for you guys, hopefully you can help me out. I have an '89 OMC King Cobra. After rebuilding the engine I was putting all the wiring back together and noticed some mystery wires that were cut by the previous owner. I always wondered what they were for so I did some digging around and traced the cut ends. I noticed the purple wire to the choke on the carb was in the wrong position. It was attached the BATT side of the coil instead of the AC terminal on the alternator. Also I found that the wire form the Ignition (I) terminal on the slave solenoid was attached at the solenoid end but clipped at the end where it's supposed to attach to the BATT side of the ignition coil (according to the manual wiring diagram).
Before I removed the engine everything seemed to work just fine. So my question is do I fix what wasn't broken? Is there a reason why the coil shouldn't be attached to the solenoid?
Let me know your thoughts.
Thanks everyone
Thanks everyone
