Hey All,
Newbie here, I purchased a older floe lift over the winter and it did not have the setup for a pontoon. I wanted bunks that would support the length of the deck as that was the style of lift we had before. I ended up with these (looks to be) homemade style of bunks that were the off the same setup of lift that I have. I am working to get the bunks setup and realized that I don't know if how I am setting them up is correct. I have attached the pictures of how I have them setup currently and looking for verification that it looks correct. I also am wondering about the vertical upright pipes, as they extend and then are locked in place via a bolt being tightened. Is there any concern with weight limits on those bolts and legs? My pontoon is not that heavy, only about 1500 lbs, I just don't want to get it in the water and the boat on it and the bunks slam down due to the boat weight. I could probably drill through the pipes and slide a bolt all the way through both pipes for more stabilization. What are the thoughts on the setup?
