Help I lost my nuts!!
Ok, someone used my boat this past couple days. I went to start it up to make sure it still ran. I immediately noticed the engine was bouncing around a bit. I looked and noticed two large nuts in the bilge area (only one shown in pic, seen one nut seen 'em all). I noticed that the bottom stud of the motor mount was nutless. Question...do BOTH nuts go on the stud show in the pic? If only one goes there where does the other one go?
Thank you. I hope you all are having a glorious day/night whatever the case may be.
Hello from Alabama.
Mercruiser 3.0
alldodge
This may be why they came off, but then again, if they where jammed together tight enough they should have held.
But hey you found your nuts :D
Ayuh,...... 'n yer gonna have to pull the drive, 'n align the motor to get yer nuts back to where they belong,.....
