There's a set of shift cables, a steering cable, and a wiring harness all run together from the rear to the console on the right side of the boat. Just add a wire to those. If you are lucky, they left a string installed to allow you to pull another wire. If you find and use it, make sure you pull a new sting (rope) when you use the one that's there now.
