motor swaps are done all the time. there is nothing special about swapping a motor.
pull drive, disconnect motor, pull motor....... transfer parts, test run on pallet, install motor, align motor, install drive...go boating
you have a fuel injected motor, so unless you re-flash your ECM, replace what you have with exactly the same dont think about more power, less power, etc. replace with exactly the same.
assuming you R&R the motor your self,,,,
to rebuild your motor, work with your local machine shop. unless you punched a rod thru the block, you are looking at about $1500-$1800
to build a new motor from parts, you will spend about $3000-$3300, then swap all your parts over
to buy a new long-block you will spend $3100-$3300, then buy exhaust gaskets and swap all your parts over
to buy a complete new bobtail, you will spend about $14k
