Okie deerhunter
- Apr 27, 2020
- 4
I have a 1990 Johnson Gt 150 with the 35 amp alternator. J150stlesb. My problem is that sometimes it’s hard to start and slobbers till it warms up a little, then seems to run ok on plane. It may run good initially but turn it off to fish, then fire it up to take off and it bogs and acts like it’s only running on three cylinders. If I stop to fish again it may or may not run right. Motor has been overhauled, along with the carbs. Linkage and timing are correct. I replaced the power pack last year and it helped some, but the intermittent run problem is still there. Tach hasn’t worked in a long time and this problem I’ve been fighting for three years. Is it possible that the stator / charge coil is shutting down when the motor gets warmed running? Or is there something else causing my misery? I hate just swapping parts as that can get expensive. I have a OMC factory manual and still haven’t figured out what is causing the intermittent problem. Help!
