While you have the Flywheel off, look where the upper Crankshaft Seal is. If it is Dry, great, if it showing signs of Oil, then it will need Replacing, as Oil getting out, means Air getting in, and causing the upper crankcase to be less efficient as a Transfer Pump. The seal can be replaced without taking the Engine apart. The Tool looks like a Piece of Threaded Pipe that fits over the Crankshaft with the treads going under the Seals Lip, Turning the Tool brings the threads into contact with the Seal housing and out it comes. Using a piece of threaded Pipe has been done, but if unless prepped properly, it can damage the crankshaft sealing surface, so beware
