Rick Stephens
- Aug 13, 2013
- 6,118
Interesting conundrum. I don't know anything about how a weighted advance system would work on a boat motor. The advance curve is not nearly as predictable as a marine programmed electronic module will give you. And may be designed for a car or pickup in road conditions and not a constant load motor like we have in boats. Your video definitely indicates you have a lean sneeze, which is either your throttle pump isn't pumping, your carb is too lean in the midrange section - depends on what carburetor is installed, or the ignition is way off.
Like MadProps, I failed a Thunderbolt module and chose to install the Delco Voyager EST in my boat. It has been perfect for years.
