Thx for the replies, although I hoped for a little more consistency...
I did get to run it yesterday for about 40 mins. The pressure came up with RPM as it should, but dropped pretty low idling back to the ramp - less than 20 psi, which concerns me. No idea what oil is in there, but will be changing to 25-40 before trying again. I'm in TX, so more viscosity is warranted.
Separate issue for any willing to help - Ran fine at varying RPMs out on the water, couldn't open it too much due to small boat in chop (18 ft Glastron Carlson). Very slight hesitation off idle but not a stumble. But at the end of the ride, when tied up, idling in neutral, waiting to trailer - it died. Wouldn't re-start without 1000+ RPMs worth of throttle. Temp on gauge was below 180.
When cold, it starts immediately and idles perfect.
As I don't know the history of the boat, my mind goes to corroded exhaust risers causing excessive heating. I got it still winterized from the Northeast, and the water coming out of the freeze plugs on the hose was clean.
Also - maybe a maladjusted electric choke..?
I'm not a fan of pulling the risers just to see if they are bad, but will - if there are no better suggestions / troubleshooting advice.
TIA
