JW in Texas
- May 4, 2020
- 24
'00 454 Mag MPI, Serial# 0M021074
This started the night I brought the boat home in 8/18, 5 tows later & numerous attempts by multiple "certified" mechanics including the dealer & we are still at square one. Frustrating is a vast understatement.
I purchased the boat in 8/18 from Lake Cumberland with approx. 395 hours. Always a marina boat on a lift, first owner put 125 hours on it in 16 years, second put 270 on in 2.5. Brought the boat back to DFW area.
Boat starts perfectly every time when cold, never an issue. Left us stranded on it's maiden voyage. Started right up, went out, stopped for a couple hours, went to leave & it just cranked, no catch. Get towed in, next morning, fires right up. We were below a 1/4 tank so I thought maybe contaminated fuel. It did live in a marina it's entire life. Pull the separator & sure enough, water. Drained the tank, Seafoam'd, new fuel pump, plugs, batteries & oil change. Took the boat out a couple weeks later, same issue. Start looking at spark, seems weak & coil is original so new cap, rotor, coil. Try again, same issue. In desperation & to eliminate basic ignition, I do the ignition module, typical GM style under the cap. Use the boat several times including a long weekend with dozens of starts, no issue...Yay! Not quite, late last season, same issue. This time, it's taken to the dealer. They spend a week with it, bow to stern, find no issues & cannot duplicate problem.. Pull codes, none. We decide I will wait until this season when it warms up & try to duplicate it.
I took it out last Monday, run it for over an hour, back to dock, kill it, let sit 20 minutes & presto, won't start. They bring down Mercruiser Computer, all looks good. Check spark, very solid. Fuel pressure is at 40-45 psi cranking, but we do have aeration & it bleeds pressure after sitting for a few minutes. Pull plugs and they are damp, possibly leaking injector{s**. Take it back to shop right then, new plugs, fires right up. Sent the injectors out for cleaning & balancing. Took boat out yesterday, ran great right up until we were ready to leave out in the middle of the lake. Had been sitting a couple hours, crank, crank,crank, no love. Get a tow back, 45 minutes into the tow, it starts. I had been running the bilge blower the entire time going back, but I don't feel like this is vapor lock. I have tried starting fluid every time this has happened & it doesn't even bump, ether has zero effect while cranking. I have had lots of experience with old cars & boats, ether always does something. At the end of my rope. Thanks for any guidance,
J
J
