BigWeakSauce
- Apr 4, 2020
- 50
Good Morning! Had my 1974 Mercruiser 165 running on muffs yesterday and noticed decent water flow coming from my prop but very little solid water coming from the exhaust holes on the gimbal ring, when I put my hand up to it I was getting sprayed with fine mist that pretty quickly wet my hand but wasn't sure if water should be spraying like a hose from there or if a fine virtually invisible mist was sufficient.
My temp gauge was reading beyond it's 240 degree max which is why I'm looking into water flow however I suspect the gauge/thermostat is faulty because upon cutting the engine with the key still on it immediately drops to 180ish and stays there even when the boat is off with key out and battery removed. When I come back to start the boat hours later the gauge restarts at 0 again but only after turning the key to on.
Any insight here? Is that light mist from the gimbal holes OK or a bad sign?
