I have no spark all the way back at the Ignition coil. I put an inline sparkplug tester from the coil to a plug and i get no light. I removed the Tach terminal from the Tachameter, i made sure the kill switch is in run mode, the shift cutout switch is open. i followed all the continuity and resistance tests in the service manual on the ignition coil, pickup coil and distributor. All the voltages are where they are supposed to be.
