tony203040
- May 11, 2016
- 7
Hello everyone!!
One of my first posts, so I hope there are no issues with it. I know there are a ton of "no spark" posts in the forums but I cannot find any posts with similar issues as mine.
Engine: 2002 Mercruiser V6 4.3L EFI TBI
Symptom: No spark, No start.
I worked to follow the Thunderbolt V Ignition Troubleshooting Flow Diagram. Troubleshooting Steps so far:
1. Performed an ohm-check on the gray cable on the back of the tachometer (to ground). Reading 0.9k ohms.
2. Checked all terminal connections...no visible issues.
3. Used a spark tester from the ignition coil to the distributor...no spark (light).
4. 12V is present at the positive terminal (in reference to chassis ground).
5. Connected multimeter between positive and negative terminal of ignition coil...boat starts (and I have no idea why). Disconnect multimeter, boat no longer starts. Uhhhhhhh...what in the world? LOL.
a. I assume a bad ignition coil (maybe my multimeter is acting as a coil?) Crazy talk...I know.
b. I replace ignition coil...no change...still no spark.
c. Return to flow chart.
6. WHT/RED bullet connector from distributor does not appear to be a bullet connector (on my boat)...it does not pull apart. Throw in the incredibly tight space...I'm not sure I'll be able to perform this test. I get frustrated and revert to my computer.
7. Digging through the forums (including Don S's "How thunderbolt systems work" post), I read that disconnecting the tachometer and shift switch can help isolate and troubleshoot the issue.
8. I am now working toward disconnecting the WHT/GRN wire from the shift switch, as recommended by Don S in his post. However, I believe my shift switch has two purple wires coming out and going to a connector. The other connector (that it is plugged into) has a PUR and a BLK wire.
9. In my tireless effort to just move along, I disconnect the connector completely. I turn the key and the boat starts IMMEDIATELY...and then dies after about 5 seconds. I repeated this three times and it dies out like clockwork.
I know I've gone slightly off course from the flow charts, but does anybody have any ideas? I'm thinking a bad shift interrupter switch or a grounding issue. Any ideas, please let me know.
-Antonio
-Antonio
