FreeBeeTony
- May 15, 2002
- 3,995
Have twin '95 175 Jojnsons....
Primer bulb always pumps up strong after 3-4 squeezes on port engine.
Stb engine does not get "hard".....even after more pumping, engine starts fine but needs more pumping in colder weather.
I replaced the primer bulb on stb engine this spring w/o any change.
Another problem I think is related is that after running for a while (~an hr or so) and shutting down to fish or have lunch....same engine has trouble getting up in RPM's......has problems getting past ~1500RPM......tends to stall out (this is in gear)......like I have to sneak up on it, once it gets up to 2000RPM's it's good to go.
Have dual tanks, doesn't matter which tank is being used.
What would cause the bulb not to get hard? I'm thinking these issues are related.......
I tried pushing the key in today when I was having problems getting up in RPM w/o any help.
Next time going to try pumping the bulb!
