Squatch0817
- May 19, 2020
- 22
I have 30 psi in both cylinders of my 1979 evinrude 35hp 2 stroke engine. its only electric start. the starter is seized up but the new one should be arriving in a a couple weeks. i got the reading of 30 psi in both cylinders with a rope pull on the flywheel. is the rope pull adequate enough for a compression test or do i need the electric starter to perform a proper compression test?
