Snowmeltriver
- May 21, 2020
- 3
First, thanks for all the thoughtful responses on this forum. I have already learned a lot.
Last spring we bought a 2003 Bayliner with a 4.3 Mercruiser engine. It's been a perfect family boat.
At the end of last season, I found a minor oil leak from front of block when warmed up. I've cleaned everything, run it on earmuffs, and isolated the leak with a mirror. I'm pretty sure its the front crank seal as that seems like a common thing. There is just a drip from the front edge of the oil pan that looks like every other photograph that people have posted with this issue. There is no circular spray pattern from oil weeping through the keyway and spinning off the harmonic balancer or crank pulley.
1) I wanted to check the PCV valve first (before swapping the crank seal) as I read that that can increase crankcase pressure and push oil out strange places. Funny thing is that neither valve cover has a pcv valve, both are just 90 degree elbows to route the vent hoses to the spark arrestor. The Mercruiser parts diagram definitely shows a pvc valve on the port side. Do I need a PCV valve? Could this be related to the oil leak?
2) How much fuel smell is normal when opening the engine hatch? I assume some gas smell is normal since its a carbureted engine.
Thanks! That's it for now.
