1970's 120 mercruiser outdrive 1.98 gear ratio vs. 1.50
Short of a 1000 gallon tank and a 4" dump valve, you wont gave enough compressed air volume to do anything
Pull the drive and look
Lowchopr
Somethings got to be in there, no water from prop or left side transom, ill pull it and check... Thanks.
Lowchopr
Update!! So i used a snap on boroscope and found no old flappers in the exhaust.... Passed the raw water test with flying colors....... Pulled thermostat and,,, walla,,water coming out everywhere,,,,boiled the thermostat did not open till 180, also possibly my homeade thermostat gasket may have kept it from fully opening....leaving thermostat out and heading out this weekend,,,thanks again guys!!
Lowchopr
Here she is in the water after the rustoleum roll on paint job!! 30 bucks. Chick magnet!!
Lowchopr
ok looks like the oil can get condensation, will get new thermostat tomorrow!! thanks again!!!
