nw_4wheeler
- May 28, 2020
- 5
I am in serious need of a solution here. I have a 1998 Chaparral Signature 240 with the 7.4l Volvo Penta GI engine. My Fuel Vapor Separator is corroded. I cannot find a replacement anywhere. I even took it to a shop to have the nipples built up with aluminum welding. This was a no-go. The mechanic believes it might have some magnesium or some other metal in it so they could not get any good welds. This picture shows what mine looks like but these pics were found online. Mine have much more corrosion on the sea water inlets than this one. I have read stories of many actually breaking off. Mine did not break but have serious corrosion. I am not against swapping out for a newer module that I need to retrofit it into my boat but I would like to minimize customization if possible.
My boat is in great shape and was in the process of replacing all seawater cooling lines when I found this problem. I found leaking down the back of the block where this is mounted. I have just replaced exhaust manifolds, risers, and many other new items. Dropping about $5k this year into everything. Was looking to keep this boat on the water for many more years and now I have this road block. Any help would be appreciated.
