This is my first post on the site. I have been getting a lot of good information reading others posts but now am stuck.
I have a new to me 73 evinrude that I don't know a lot about the history other than like everyone else, was told it ran great before. It will start up and idle/ rev on muffs even in gear but once in the water, it will die once it is in gear. You can ease into the throttle and there is a sweet spot that it will run about 5mph but nothing more. If you go higher sometimes it will surge like it wants to go, but will eventually die. We have replaced the gaskets on the exhaust/ cooling side because if a small leak as well as a new head gasket/ thermostat. All 3 carbs have been removed, cleaned, and rebuilt. All fuel lines have been replaced along with the fuel pump except the main line from the tank to the motor and the bulb. The tank and that line/ bulb looked newer when we got the boat. The compression has been checked and was between 135-138. The throttle cables have been replace, throttle cam adjusted per the 4 31/32" requirement, roller set of from the cam but the mark centered when no throttle is applied, and the spark advance lever moves freely.
I am completly lost on where to go next and dont want to keep throwing money at it with no fix... can anyone help?
