Need advice. I recently resumed work on my rebuild. Upon drilling into my "new" transom I found wet wood in the lower portion. I have removed a decent amount and found the extent of the water. The remaining wood is in excellent condition, cannot tell a difference between it an the new stuff I just bought.
I found that the lower ~1/3rd of the transom around the hole was wet. The question is given good wood could I splice another piece into the bottom and re-glass avoiding hours of work and itching or go ahead and make a single all new transom? I went ahead and split the second layer of wood off so I can make a good bond with a single piece.
Pic attached is with 75% of the second layer gone and all of the wet wood removed back to solid like new wood on the right side. I am figuring that the moisture soaked into an approximately same size area on the left.
I am concerned about strength of the finished product. I am pretty sure with a decent enough glass job it will be fine but I wanted to ask the question before proceeding.
