iknowalttl
- Jun 1, 2020
- 35
I have a Rinker Captiva with a 4.3 and alpha one gen one outdrive... was going to replace the impeller and noticed a little heat damage to the base of the water pump so I was going to replace it... when I pulled the base out I noticed that the bearing seal was not built in to the base like a different drive I have apart and the replacement part I have has the seal built in and the bottom where it mounts is extended with a place for an O ring... I also noticed that the shaft on the drive I was running has play side to side so I assume the bearings are worn... the kit will fit the other drive foot and the shaft is nice and tight... all else seems the same except it has a pre load pin in the top of the shaft... so I want to know if the foot part of the outdrives interchange? I want to put the foot half of the outdrive with the load pin on the top half of an outdrive where the foot did not have the load pin... am I looking for trouble or will this work just fine?
