Wow, so I went back to rechecking the torque specs on the bolt. I had stripped out the first couple of threads on my crank bolt when I went to torque it to 74 lbft per the Merc manual. When
Scott Danforth mentioned 60 as the max, I double checked the manual. Anyone care to chime in on these screenshots? Also Scott, my bolt was 2.23" below the head (actually that was the measurement on both engines). If the true torque value should be 40, then a) it's no wonder I stripped it out, and b) this is the second time the manual has screwed me in short order with inconsistent values. We're approaching Clymer time here.
i was able to tap out my threads, but they weren't in terrible shape and were only the first few threads. I'd be worried about getting a tap in there straight if the threads are stripped all the way. If your tap was off, you might get a ton of wobble when it runs and the bolt wasn't parallel to the crank, but maybe not.
