I'm planning on changing out the thunderbolt ignition on my 5.7 chevy motor. The new marine distributor comes with a two wire lead. It has the coil in the cap. One lead goes to 12 volt keyed and the other goes to the tac. If I do this, how would i wire the shirt interrupter? I'm assuming the distributor grounds thru the block. So there is no way to interrupt the charge going to the distributor from the coil. Hook the interrupt to the tac wire? Has anybody done this conversion before?
