Hello
First time posting on the forum, but have been lurking around since I owned my boat. You guys have been amazing helping everyone with their issues. Well, I have a problem now that I may be needing some advise on. I have a Regal 2150 LSC with a Mercruiser 5.0 Carburated, Serial 0L094405. 2 weeks ago my engine started up and ran okay. There was a solid alarm that came on after the engine is hot, so I immediately turned off thinking it's overheating. So I figured I would take out the bottom out drive to change the impeller because it's never been changed since I bought the boat. I also changed the circulating pump (water pump) on the engine. My engine is a closed cooling system (coolant). So after changing all that, it's now just cranking and won't fire up. My question is, would changing the impeller and water pump have any affect on the ignition system? It's been driving crazy and I have look through the forum, and did all the tests for sparks, fuel and air. What else could it be?
thanks in advance
thanks in advance
