Ignition sensor was replaced White/Red wire is connected and White/Green is disconnected.
White/Green wire is striked rapidly against a ground and there still is No spark?
You have 12V on the White/Red coming "from" the TBV ignition module?
The rotor does have the metal fins which pass by the sensor in the distributor?
The rotor does turn when the engine is cranking?
