Kiska Motorworks
- Jun 8, 2020
- 10
I'm working on a mid 80s Evinrude 40 horsepower for a gentleman. he hooked a battery up backwards and since then, he says he's not getting any charge to the battery. He had previously replaced the rectifier (3-phase 3-yellow) with a used rectifier, and it is testing just fine. Full diode test and resistance across all the yellow wires and grounds, and everything is testing as it should. In addition, I have tested the stator, and it tests fine as well. very slight resistance across each phase and no evidence of any short to ground. Even tested ac voltage when running and it seemed to be right in line with RPM from about 15 up to 50volts as it should be. Everything is wired correctly, yellows to yellows, red of rectifier to red of motor, gray wire in with yellow and gray wire etc, but I am not getting anything but battery voltage at the rectifier or at the battery. Hooked up to the hose, up to a couple thousand RPMs, but nothing changes. Even tried a different brand new battery but no difference. On a small aluminum John boat.
Thank you so much. Trying to get this figured out for the guy before I head off for Coast Guard duty on Friday.
