2001 FourWinns Horizon 200, VP SternDrive 5.0Gifeps SX-M 1.60
Recently replaced;
TPS
cap
rotor
plugs
serp belt
serviced fuel pump using Mancave Mech's instructions and oring kit
fuel filter
injectors serviced/cleaned
regulator diaphragm replaced
throttle body cleaned, gaskets replaced
Boat idles fine at 650rpms on muffs in driveway, will idle and move around at low throttle in water, upon reaching end of 5mph will get up on step easily and do fine at WOT, but upon adjusting throttle even a little engine floods. When i remove the spark arrestor and open butterfly valves i see a lot of fuel and fuel vapors escaping. Once they all clear out i can repeat the process. If i stay at rpms under 2k and don't touch the throttle it seems like it will run all day at that speed, until i adjust it again. moving around at anything under 1k rpms it doesn't stall out.
Cheked the Map sensor with a brake bleeder vacuum pump with the key on, it gives an initial read out of 3.5v at 0"Hg
2.75v at 5"Hg, 2.0v at 10"Hg, 1.25v at 15"Hg and .75v at 20Hg.
Any help would be greatly appreciated.
Matt S.
Recently replaced;
TPS
cap
rotor
plugs
serp belt
fuel filter
Matt S.
