GreatVegetable
- Jun 10, 2020
- 6
Hello,
GreatVegetable here, new to the forum.
I recently purchased an old 17' canoe and am currently in the process of setting it up with a Minn Kota Endura C2 55lb thrust trolling motor and I am seeking a bit of advice on setting things up safely and properly.
I have the Minn Kota Trolling Motor Power Center, and I am planning to power the motor with a Duralast Group 27 Deep Cycle Marine Battery or something similar.
For a charger I want to use a POWISER 3.3W / 12v Solar Battery Charger/Maintainer.
The panel comes pre wired and is hooked to the power center using alligator clamps to the battery leads and can also be converted to use a 12V DC car inverter instead. This panel does not use a charge controller but is designed to not overcharge the battery.
The power center box has the external battery leads and two 12v DC car inverter outlets, so my first question is, can I charge the battery effectively using the 12v DC inverter or would it be best to use the alligator clamps on the external leads?
My second question is, can I have the solar charger and the trolling motor hooked to the same leads at the same time, and use the charger to maintain battery power while using the trolling motor?
Any advice would be greatly appreciated.
Thanks,
GreatVegetable
Edit
Thanks,
GreatVegetable
Edit
