Hi
my 1992 Evinrude 140 misfiring pops and dies at idle
every once in a while there is a slow down and pop like every 10 - 15 seconds
i have rebuilt the carbs, sprayed around them when engine runs - no difference
changed power pack - same behavior
compression is good everywhere
changed plugs - no difference
disconnected kill wire - same problem
for now i disconnected the black/white wire to temp sensor and idle is at 1200 rpm which would cause the engine not to stall in idle often, but still may stall
when boat is moving in water and rpm is above 1000- no stall i guess because the inertia does not let the engine slow down quick enough
i am able to run the boat in water above 4000 rpm - seems ok
i am totally out of ideas now...
1992 Evinrude 140
no VRO (removed a while ago)
1992 Evinrude 140
