Hello all, I have a VJ60TLESM. It runs relatively well though I had a bit of trouble over the weekend. I was “plowing” through (not trolling, not on plane) a choke point on my lake. The motor bogged down and would not power back up. Same with choke in neutral, I could not get the revs above 1500ish without the motor bogging completely. It would idle and troll fine. Of I shut the motor off for a short time it would fire back up and run without issue, this problem only occurred when I was plowing. From what i’ve read, about others with a similar issue, it seems to me like an overheat issue.
I don’t know much about the VRO delete but do know it has been done to this motor. There was a wire sheered sitting in the splash well, pic attached. It looks like that was overtemp sensor. It is a twon conductor black cable connected to frame ground and brown wire (no stripe) Should that not be connected or is it a reference to VRO temp only?
