what's on the other side? Is there a live well?
No, the top goes straight into boat. So if water gets in, you can take off plug to drain water inside. Curious if i can leave it open so if there's water it can auto drain itself out but seems like water can drain inside as well.
That's a weird setup. I'll assume the lowest plug is the bilge. How high above the water line are the other two plugs? Can you post a couple pictures from the inside of your boat?
