I have a 1997 Regal Destiny 200 4.3lx Gen2 with 2bbl carb. Out of the blue the fuel pump doesn’t run. I have done the following trying to find the problem. It will run going directly from the battery to the pump. Bypassed the oil pressure switch and got no power to the pump. Ran power to Purple/Yellow wire at the oil pressure switch and fuel pump worked. I need help finding the issue as I’m not sure what else to try. I think by putting power to the Purple/Yellow wire at the oil pressure switch it eliminates the starter solinoid since the pump gets power... of course I could be wrong in that assumption. Anyone have any other test ideas? Any help would be greatly appreciated!!
