2000 Sea Ray 210 Signature series bowrider
Mercruiser MCM 5.0L EFI
Engine serial number: 0L641983
First off just want to say that this is my mom's boat which isn't local to me so trying to get a list of things to check / test before going. I was up there once trying to figure it out, but the starter gave out and blew the fuse so wasn't able to get very far. (dont believe it's related at all, changed the starter and fuse and it's back to doing what it was doing before).
Boat has been having issues starting randomly. Seems to start when cold fine first time of the day. She usually drives around a little bit, then throws anchor to float for a few hours. Outside temps in the 80s- low 90s lately in southern Wisconsin, so maybe it's still a heat issue even though it's sitting for a couple hours? Goes to start, and it just cranks. It tries to start but then sputters a little bit and dies. The more you try to start it, the worse it gets and then wont fire at all. Safety switch fine, it's in neutral, etc. Gets towed back to dock (4 or 5 times now). Lets boat sit for a couple more hours, then fires back up later on when she goes to put the cover back on for the night like nothing happened.
She's had a mechanic out a couple times now and he swears it was going to be fixed after the last time. He's replaced the ignition sensor, cap, rotor, and coil now so far.
Mechanic showed her how to look for fuel being sprayed, and she says there is
